1 - 2 of 2 Posts
Battery is fully charged but starter periodically clicks when trying to start. And @ times headlight will not come on right away. The light will come back on after bike is running awhile, usually while going down the road. When the starter clicks I can start the bike with a push button installed @ the starter, fires right up.
I'm going to start with checking all of my connections. Was wondering if any of this sounds familiar or anyone has heard of this problem combination before?
check the ground wire. another guy suggested on another starting problem
to use a 10 gage wire
hooked to the gnd post and touch the front part of the bike so to see if the headlight
gets stronger. if you replace the ground wire seal the ends wirh RTV. this will keep corrossion out.
1 - 2 of 2 Posts
