Probably a common one, but here goes:
2011 Fatboy, SE stage 1 air cleaner, rush slip-on's with 1.75" baffles. Everything else is stock. The pipes should be delivered tonight and I'm anticipating installing them tomorrow.
One last question... With the PCV, does the bike have to be running to implement the new map?
I appreciate all the help you give to us out here on the forum!
Den
Denfire621,
On the Power Commander V's you do not need to have the bike running or even turned on for that fact. It was only the older PCIIIUSB models that need to be powered up in order to send a new map to the unit.
Thanks for the quick reply!! Is there a specific map I should be using? Do you folks have one cooked up there?
Den
Thanks a million!
Thanks! On shift tomorrow, will give it a shot Thursday and tell you know how it works (provided it's not raining!)
Den
Discussion Starter #6
Excellent!!
Just loaded the map and "got on it!" All I can say is WOW!
I'd tried the canned map for the screaming eagle pipes (M15-004-003) and it ran alright. I tried the map you sent and there was a big difference! Thanks for helping me/us out!
Den
