I have a '03 heritage and installed a PCIII with the intent of future upgrades. I now have the SE air filter and will be getting V&H Bigshots in about a week. Is there a map for the PCIII for just the SE Airfilter...or is it ok to run it with stock map, or should I hold off and install the Air filter at the same time as the Pipes and the worry about the map then.....
Any insites welcome...
Chris.
I would wait and do it all together, they all need each other for best performance anyway............
Thanks for the reply....
Is it possible to do any engine damage from running SE air filter without reflash? From running overly lean or other?
Chris.
EvilMonger
I would do all at once, I have heard you can do pipes without air cleaner and re-flash but not the other way around??
Alien is correct, it is common to do the pipes only due to the HD sounding like Honda 150 new. Most already have the pipes installed when they upgrade to the Stage one.
