I just received my PCIII today. I didn't install it yet. I do not have a laptop so I must change the map using my desktop computer and then install the PC. On the CD that came with the PCIII there is a map, "M807-005" and the same map is on their website. The map is for the touring models and matches the changes made to my bike which are,
Screamin Eagle touring mufflers
Screamin Eagle air filter
Stage 1 ECM
My concern is that the Map is listed for a 2002 model. My Street Glide is a '06 model. This is my first Harley and I do not know if there is any difference in the EFI between the '02 and '06 bikes. Will the Map dated for 2002 be OK for my bike? One more question. The PC has instructions on how to change the map using the 3 buttons on the unit. The instructions are confusing and vague to me. I do not have a laptop and it probably would not be practical to remove and re-install the PC when I need to adjust the map. Can you get the same results changing the PC using the 3 buttons as you would using a computer? Thanks.
eddie
Stage 1 ECM
eddie
