Deluxe said:I just had my PC III USB installed but can't get a map for my build so if anyone has a custom map close to my build and can send me a copy or suggestions.
05 Deluxe
95" BB with /flat tops
SE 204/cams
SE 16ga pipes
Stock Heads
Stage 1 down load
SE A/C
Dave
As soon as i put a few break in miles I will have a custom map made up my dealer recomended one the next state over from my area I was trying to find one a little closer to my set up mechanic said the one he down loaded should be ok until then the one he put in isSteve Handy said:Dave,
If some one sends you a map print it and use it to cover a crack in your wall :whisper: not that is a bad map but its NOT CUSTOM TO YOUR BIKE....
Look at PC web site and find a dyno guy in your area ,its worth $175-$250 to get your bike dialed in RIGHT.
Good Luck
Steve The Dyno Guy :cheers:
New motors are prone to piston scuffing (caused be getting hot ) cool weather best time to break in :banana:Deluxe said:Steve
My mechanic had mentioned that he didn't hear any detenation but told me to pay attention for it until I get it on a dyno what do you mean don't get it to hot in cold weather I'll ride until the snow comes .
Dave
