1 - 8 of 8 Posts
I just purchased a PC3USB for my 01 RK. The following was displayed in the the Control Center software (toolbar, VIEW - POWER COMMANDER INFORMATION).
Born on date: August 9, 2004
Firmware: 1.0.1.20
I just purchased this thing and I was wondering about the ~1 1/2 year old date. Other than with the REV X-TEND firmware upgrade, is this the newest firmware version?
What do you guys have...:unsure: :unsure:
michiganfatboy
Thanks for posting! I see you have Power Commander Control Center version: 3.0.9.0. This can be upgraded free to version 3.1.3 from PowerCommander.com. It would also automatically upgrade your Power Commander Communications version: 1.3.0 to 1.3.2.
What about your FIRMWARE version? While connected to your PC3USB, open your POWER COMMANDER CONTROL CENTER. Go to the VIEW menu bar at the top. From the displayed drop down menu select POWER COMMANDER INFORMATION. This will display information about the firmware version of the actual PC3USB chip.
I just purchased mine indicates the chip is 1 1/2 years old and firmware version 1.0.1.20.
What does it matter? Probably not much. Just like desktop computers, I would image the PC3USB firmware has a few tweaks here and there that make it work just that much better. MOSTLY PEACE OF MIND I guess.
Thanks for your input!! :beer: :beer:
Even my cologne is chrome
firmware info
Map Version: 108
Born On: Wednesday, May 19, 2004
Firmware Version: 1.0.1.13
Mode: Basic
Button Values:
Fuel Change Per Bar: 5%
Low (0 RPM - 2000 RPM): 0%,
Mid (2001 RPM - 4000 RPM): 0%,
High (4001 RPM - 6000 RPM): 0%
Looks old to me. Anybody else? Does this matter?
-MFB
Discussion Starter · #6 ·
MFB
Here is my complete info.
Map Version: 118
Born On: Monday, August 09, 2004
Firmware Version: 1.0.1.20
Mode: Basic
Button Values:
Module Information
Module: 0
Serial Number: 040804001400
Firmware Type: Firmware Type 0
Channel 0 Type: Fuel
Channel 1 Type: Fuel
Channel 2 Type: Ignition
Channel 3 Type: Ignition
Purchase date and born on date are similar.
Anybody else?
I have the following setup and cannot update the firmware through the USB - I get an error....is this because I have an older PCIIIUSB and can't install the firmware update myself??
Thanks!
Map Version: 108
Born On: Friday, March 26, 2004
Mode: Basic
Button Values:
Module Information
Module: 0
Serial Number: 040303004764
Channel I Type: Fuel
Hub Info:
Hub not found.
Wisyooper
I just updated my software yesterday.
Go to the web site and down load the new software, it will be a zipped file,
take the unzipped file and save it in the folder on your computer.
when you update your software pick the file you just saved. When it is updated I noticed the low mid and high were all color shaded on the PC.
Also make sure the 9v battery is new when you do the update.
1 - 8 of 8 Posts
