The dyno information you posted did not include the AFR information. If is there any chance you could get the actualy dyno file (not just the print out)? Assuming that the AFR is correct with the map you have installed I do not see any big gains to be had with an "advanced map". What is your expectation for this engine package? It makes quite a bit of torque from very low in the rpm range and should be great to ride.
If you did not see the HP numbers from the dyno would you be unhappy with the way the bike runs? Do you normally rev the bike beyond 5,000 rpm in daily riding? If not, I don't know that changing this to just increase the peak power number (and possibly reducing lower end torque) would be worth it.
You migh see more peak by removing the baffle in the Pro Pipe. However, this is going to make things really loud (this pipe is not quiet to begin with) and can reduce low end response. Bigger cams might also be in order.
Think about what your goal is and we can go from there.
