For those that use a generic map from Power Commander, without checking the bike on a dyno, you maybe looking at picture like this in the future. I'm in the middle of a 95" kit install. I removed the rear cyclinder head and saw a large amount of carbon buildup. The bike ran fine and the rear plug was a little darker than the front. I contacted PC tech support and questioned the map. They informed me that PC only maps from the front cyclinder. Guess I can say lesson learned by not getting the bike on a Dyno for a proper tune.
Pc reply :
We have also found that in most areas the rear cylinder does run a bit richer. One of the benefits of the PCIII USB is that it allows you to map the front and rear cylinders independently. By developing a custom map you can assure yourself that both cylinders are running optimally. When we develop our maps we map the front cylinder only.
Pc reply :
