Sure can. I just did it yesterday on my Road King Classic. The hardest part was getting the trim ring off and back on around the head light. I used the attached diagram.Chuck K. said:
Sure can. I just did it yesterday on my Road King Classic. The hardest part was getting the trim ring off and back on around the head light. I used the attached diagram.Chuck K. said:Any one know how difficult is to make the passing lights stay on while the high beam is on. I cannot figure why most all vehicles are set up this way, on a open road needing your high beam why disable the passing lamps which could help light things up? :huh:
I went through the same problem with my jeep but I installed a jumper in the relay that allows the fog lamps to stay on with high beams. Can the same be done on a 05 heritage soft tail? Thanks for any help. Chuck
Most State Laws require passing lamps on with low beam only. (found that out the hard way)Chuck K. said:I cannot figure why most all vehicles are set up this way, on a open road needing your high beam why disable the passing lamps which could help light things up? :huh:
Most states wouldn't like my low beam with the passing lights. Everyone flashes me cause they think I have my brights on. Then I flash them the brights.ssgjwarren said:Most State Laws require passing lamps on with low beam only. (found that out the hard way)
Ah but I have also put in brighter bulbs.:brows:road_king said:The reason why cagers flash you at night with the passing lamps on is that they are aimed straight ahead verses slightly down like the headlight is. Comes from the factory aimed in that manner. If you look in the service manual you will see the adjustment procedure states to line them up "straight ahead with the center of the main light beam even with a horizontal line drawn on a wall 25 feet away."
I get flashed at night as well. I have often thought to aim them down some, but that would make them less noticeable during the day.
What he said. Sounds just like the FLHs minus the switch.ssgjwarren said:On the Heritage, you will need to remove the Yellow wire that runs to the passing light switch and conect it with the Orange w/white tracer wire that is located at pin 1 of the plug for the head lights. This is the accessories power, it is used for all running lights.
They should be in the headlight housing just like on my Road King Classic. Double check your shop manual to be sure. Remember the trim ring is a pain to get off and back on. At least it was on my bike.dmac122 said:I have the diagram to make the modification, my question is on an EG are all the wires in the headlight housing or the inner fairing? or both? Thanks.
You do know that the headlight will aways stay on if you turn the switch to the start position. Turn it to accessory and the lights shouldn't come on at all.eglide1 said:I made the wiring change on my 03 eglide.
I thought I followed the instructions from the rustler web site and they stay on for high and low beam but I can't shut them off with the switch on the fairing. They do shut off with the key so its not the end of the world but if I switch on ignition to acc. the passing lights are on. I like listening to the radio while I work on or clean the bike and the light will run down the battery. Anybody have any ideas?
On an EG, all the wiring is behind the outer fairing. Just take it off and everything is right there. No wiring in the headlight housing on EG's.dmac122 said:I have the diagram to make the modification, my question is on an EG are all the wires in the headlight housing or the inner fairing? or both? Thanks.
