my 05 dyna has a clutch cable that attaches to the clutch release cover. Behind that are 3 or 4 socket screws that go into the bike that are lined up vertical.
Can anyone tell me where or what section I would find the drawing showing these screws and identifying them as a part either in the parts manual or service manual?
thanks
the side door that holds the shaft bearings behind the clutch release cover
has two 1/4 in bolts (84-108 in-lbs) and four 5/16 in (13-16 ft-lbs). hope this
helps.
04
be a 5/16, a 1/4 is above it (top right hand bolt). i do have 2 bolts coming
out the back side of the door that the header brace bolts to, take 1/2" nuts.
got the day of so i'll tell you what i can.
04
04
What I'm looking at are socket head screws
I think a number 27 allen is the one I'm looking at right behind
The hose line that goes into the side
sorry, went for a ride, f'n fork is banging, gonna take it apart this winter.
yep its an allen. wife just got off work, we're pullin on suds on the back
porch..ill shout out in a bit...forget the size offhand.
04
try a 1/4" allen. too much stuff in the way and i've never pulled the cover
or door. let me know....whats up..got a leak?
