I have read many places the TW37 tops out at 9.8:1 , does anyone know what the TW26(G)s optimum compression ratio is ? I saw Bill Bishop using 9.25 on his Stage II . Thanks to all in advance
Different people have different approaches, I tend to run the 37 at 9.5 or 9.6 tops, and the 26 at 9.2 or 9.3 tops, looks like Hammer and Hippo are on the same page.
Thanks Hippo , had a wonderful chat with HDwrench yesterday and we decided for my build and riding style the 31G was the best choice.
Based on what one reads on the forum that should put a smile on your face also.
Knower of Stuff
Okay guys, if I run a 26g with 9.3:1 compression on a 95" motor on a carbed bike, can I use the stock ignition module or do I need to to get one that retards the timing say 5* to avoid pinging with 93 octane gas.
Thanks in advance for you replies.
it ought to be fine
190lb ccp is optimum. Use a Crane or DTT ign for adjustability and a little more snap. Stock will do and DTT or Crane will do better. USe the compression calculator on the RSR to determine dynamic compression. X.X/1 numbers are not all that meaningful unless you factor in the camshaft timing and altitude.
