After my brief mistaken foray into the world of Qwiksilver, I have returned to the land of Keihin. I do have both a 40 and 44mm CV and I was wanting to know if any one has any "starting point" jetting recommendations. I have used (and currently do) the "old trick" set-up that I have seen posted before that uses the sportster needle, the 1/8th inch hole in slide, etc. Currently I have a 98 evo 80ci, ev46 cam, crane hi-4 single fire ignition, vance & Hines 2into1 pro-pipe, (I am about to install an ev-27 cam because of some gas puking out of the carb I am having at sustained high rpm/ high speeds, hopefully reduced overlap will help reduce this!) THANKS!
