Does the capacity of the oil tank need to be precise? I'd like to switch my '77 ironhead from a kicker to an electric start, but I don't want to spend $200 on a tank, so I figure I might be able to make one myself.
Thanks,
-Mike
No Mike, as long as you have enough oil to get through the engine and back to the tank without sucking air, you will be fine. Harley air cooled use a dry sump system and stores the oil in a tank not the crankcase. Be aware that it may run a bit higher in temp. (the oil) and you should consider changing it more often. 2 quarts will suffice.
Sounds good.
Would it help if I put the output and input lines on opposite sides of the tank? I also have an aftermarket oil cooler.
-Mike
Feed from the bottom
Return in the top
Vent to the top
Look at the stock tank (if you have one) to understand the layout for the lines.
