1 - 8 of 8 Posts
Does anybody know the exact dimensions of the Oil pressure valve? I lost mine and was wondering if anybody could give me the dimensions so I could have a tool maker make a new one for me. Thanks in advance!
Do you mean the oil pressure relief valve? Could you give a little better of a description?
Somebody must have a take-off scored cam support plate that has a valve in it. Maybe they'd be willing to give it to you. Have you asked HDWrench??
Careless me ...
I did mention it to HDWrench but gave no indication to him about needing the dimensions at the time. At the time I had one on order but the order was being held up at my local HD shop due to conditions with their purchasing department. I called the local shop again today and he assured me that the part will be here this week. I should have been more careful with the cam plate once I took the spring out. My first HD wrench job and a lesson learned. It shouldn't cost that much for that little part ... but then again who knows. Thanks for the reply.
Here are the measurements of mine.
Overall length 1.187"
Outside Dia. .435"
Inside Dia. .344"
Can't measure the degree of the bevel for the seat.
Good luck.:yes:
Discussion Starter · #7 ·
Thanks for the dimensions
If I don't get the part in this week I'll just have a machinist make the part for me. Thanks for your post on the measurements!
Highly Seasoned Rider!
I guess you could make such a part but I wouldn't attempt it. That part is centerless ground to a very high finish. You could probably order one and get it within a week for less than $10.00. If the fit and finish is incorrect, it could stick in the bore.
1 - 8 of 8 Posts
