1 - 9 of 9 Posts
I am sure this has been discussed b4. After 12,000 miles on my 2000 RK i am noticing oil blowing out behind KN air filter. Actually spraying on y pipe and saddle bag. Its a fine spray and if you rub finger under air filter cover, you get oile on it. I notice the smell more on high revs and when cracking throttle. Any advice will be Much appreciated.
Pestilence
Oil tank overfilled
Cracked\plugged\pinched breather hose
Oil pump out of alignment
Air filter oversprayed.
Let er rip!
Someone more qualified will chime in. I assume your next step should be a leak down test. The oil is probably coming from your breathers.
Let er rip!
That's usually easy to figure out because it's nice clean red K&N oil.......
Discussion Starter #7
not an overspray issue here. Started doing it many miles after filter cleaned. 3,000 miles. its def a motor oil color.
Let er rip!
Check out the engine mod section. This very issue is being discussed.
Flying low
Mine was oil pump alignment, or O-rings. Started "all of a sudden", but got progressively worse as time went on. During a cam install I realigned the pump and replaced all the O-rings, all's well now.
1 - 9 of 9 Posts
