1985 FXRS, I have a slow oil leak from the hose at the oil filter mounting bracket where the hose connects to the 90 degree barbed fitting. The fitting is loose in the filter mount and I need to remove the filter mount base in order to tighten the fitting.
How do I unscrew the filter mount, I have put considerable torque on it and it does not move, not sure from looking at the parts book how it's mounted. Looks like the threaded pipe the filter screws onto goes through the mount and into the trans housing? I'm afraid to put any more force on it.
