ok so ive been trying to figure out this oil leak im having and it appears to be leaking where the heads bolt to the barrels. i look in between those fins and see oil residew there. Ill list the engine specs below. im almost positive i torqued the heads down to specs before i put the motor in, could they have come loose? if so can i just retighten or do they need to come off and replace the gasket? If i need to replace the gasket which kind and squish should i use? is this a common issue? thanks all
Engine specs
1999 crank and engine base
95" Wiseco 10.5 compression pistons (domed)
2006 stock 88 heads
211 cams
Engine specs
2006 stock 88 heads
211 cams
