17mm Socket......oaksmith said:Just wondering which or what type of oil filter wrench you all use and might recommend?
Ah, brighton HDdzlfitr said:I let the dealer do it. $19.95
Not a special, an everyday price.
I can't even buy the oil for that price.
xxxflhrci said:I use a regular metal band kind. No problems sliding it by the sensor.
Same here!MegaGlide said:The one from H-D.Doesn't hit the crank position sensor, and reasonably priced.
cut the bottom and some of the side off a 2 liter pop bottle and hold that under filter when you finish unscrewing the filter. leave the cap on.jkane said:I use soemthing my brother showed me. It's like a hugh pair of pliers. Got teeth right on the tips and the jaws are rounded like a filter. Can only move it a 1/8" at a grab, but it works. Just a few grabs and off it spins.
Now to figure out how to not spill so much oil all over!
Slide a bread bag or any plastic bag up around the filter as you unscrew it.jkane said:Now to figure out how to not spill so much oil all over!
wyodude said:Slide a bread bag or any plastic bag up around the filter as you unscrew it.
Also, don't forget about the trick of using the new filter box:jkane said:Now to figure out how to not spill so much oil all over!
