HATER OF THE GRAVEL!!!!!!
It looks to be a good cooler, but I too would like to hear form someone that is using one first.
Pioneers, get to reap the benefits of the new and improved...............but sometimes they also get arrows in the a$$.
I'm sure the Ultracool units are effective but they sure are LARGE! Thankfully I don't need one of them as I have a Jagg 10 row low mount for my 103 Dyna and that's plenty. -Tutt
I talked to them on the phone, it seems in a couple weeks that will have there new designed, duel fan model available that is more effective and made for 103+ engines.
I will keep us in loop, but the new model they say will hang lower and is wider.
It is made for riding in heavy traffic, like LA type traffic.
Most of it in made in Hollister California, and is where they are located.
There was a handful of guys I know running them on trikes, most pulled them off. They had issues with the fittings on the cooler pulling apart and starting to leak. There were unconfirmed rumors of the cooler causing the trikes to run warmer when it is used to replace the factory cooler. I've had good luck with Jagg coolers.
