You got two plugs that look the same in the oil pan, one is pointing down, that's the trans, one pointing forward, that your oil, remove it and drain the oil,clean any metal residue stuck to the magnet, put it back make sure is tight.The plug next to it that looks different don't touch it that is to connect a oil temp gauge, change the filter add oil make sure is syn and for motorcycles, you're done.
