Is there any other oil change kits or oil and filter that people are using for their victories? I usually use the oil change kit by victory but just curious if there is a better and/or cheaper oil/filter?
Sent from my SM-G930V using Tapatalk
Wix and hastings make filters for everything. Available at any auto parts store as well as the oil...cheaper? Maybe but much more convenient and usually better quality than oem..
Check out the Victory form. They have all the information you need.
Click on Victory Forms on the left side of this form.
ttucliffhanger: Opinions are like ...... you can do a little diggin and make your own mind up.....there are many good substitutes for VIC oil... nothin wrong with VIC oil but $$$$
I and many folks run Rottella T5 15w-40 and T6 5w-40 with great results, and much cheaper than VIC oil...
Oil Filters:
WIX# 51356 OR 51358
NAPA GOLD # (4)1365, #1356 OR 1358
NAPA PFL 41365
SUPER TECH - ST7317
MOBIL 1 M1-110
BOSCH #3323 OR 3300
POLARIS #3084963
K&N-198
PUROLATOR ML 16851
OIL DRAIN PLUGS:
M12 X 1.5MM
OIL DRAIN WASHERS:
12MM ID X 19MM OD X 1.3MM THICK – COPPER CRUSH WASHERS ARE SAME WASHERS USED ON
TOYOTA R22
NAPA – BAG OF 25 APROX ( $6.00)
CONQUEST CUSTOMS DRAIN PLUG CRUSH
WASHER REFIL KIT A DOZEN FOR APROX $6.00
WITCH DOCTOR 5 PACK - # DP-WASHERS $4.25
