Has anyone come up with a cleaner, less-hassle way of draining the oil on their bike? I have a 1988 FLHS Electra Glide Sport. The oil drain is on the side. I do a lot of prep work to avoid dripping oil on the bike. I can pump the oil out, but I am not sure if that is as thorough as draining it. I have looked for, but not found a funnel for just this purpose. Ideas? Herm
Premium octane member
Long piece of bent into a V shaped piece of cardboard. I been using that way for a while with no mess at all. Obviously the bottom of the cardboard in to the drain pan. I keep the bike straight up when doing this and do it warm...Just my .02
Get one of these. Fairly cheap and works real good. You probably want to use a longer hose though. Just make sure the threads are 1/2 x 20.
LOOK HERE
