Ever since I rebuilt my top end on my '96 Heritage, I have been getting a lot of oil blowing by my air filter. My rebuild included S/E Heads, S/E flat top pistons(.005" over)EV-46 cam, S/E ignition module. S/E coil, S/E adj, pushrods, and new rockers. I used Harley top end gasket kit C/W umbrella valves. Any ideas what is going on here.?? Thanks for your ideas.
You need to check out pump common on a evo for trach to slightly damage pump and it not scavage as well. Or are you talking when you start it is pukes oil on the ground??
also have seen oil return passages on those heads being almost closed with casting flash and did you replace the breather gear?
