Crazy as a Bastard
My odometer on my 04' Electra Glide is stuck in the Trip A position. Can not get it to switch between Trip B and odometer. Pulled the fairing and popped the stwich off the inside of the panel and did some wd-40, it was sticking when you pushed the switched, but nothing. The odometrer will work and count off the miles, just can't get out of that one mode. The switch is sealed and runs into the speedo harness plug.
Any thoughts, other than taking back to the dealer.
(Posted this in the Touring Forum as well.)
Jump between the two wires on the switch and see if the display changes, if it does, then the switch is bad and you need a new one.
