1 - 2 of 2 Posts
Crazy as a Bastard
My odometer on my 04' Electra Glide is stuck in the Trip A position. Can not get it to switch between Trip B and odometer. Pulled the fairing and popped the stwich off the inside of the panel and did some wd-40, it was sticking when you pushed the switched, but nothing. The odometrer will work and count off the miles, just can't get out of that one mode. The switch is sealed and runs into the speedo harness plug.
Any thoughts, other than taking back to the dealer.
speedo
Take a wire strip off the insulation on both ends. Stick one end in where one of the wires from the switch goes into the plug. Then momentairily touch the other end where the other wire goes into the plug if the mode changes the switch is bad, if not then the module/speedo is bad.
1 - 2 of 2 Posts
