I posted this in the EFI forum too by mistake.
Went to start bike this morning and pump primed...hit start button...it clicked once but died.
Now the pump won't prime....when you hit the start button it does nothing...no click...no start...nothing.
Lights come on like normal but nothing.
The no prime related to the starter issue or is the starter issue related to the no prime or what?
TIA.
How 'bout some simple stuff....
Fuses
Battery
12v switched power connection (& ground) to your TCFI
All connections good - ECM, battery cables tight, sensor connections on TB, fuel pump connection, starter connection
My bike did the same thing you describe when the battery had gone t!ts up, wasn't much more than 5 months old at the time.
If it has the switch in the console, check that. I have a '06 RK that does the same thing. I just move the switch around till the speedo light's up and then it will start. A friend has a '07 Softtail that does the same thing. Hope this helps.
