· Need For Speed
Are all the new parts high quality brand name ? I have had new "cheap" parts fail upon installation. Check all wiring connections, could be a bad ground, maybe a different condensor.
Usually something simple.
Good Luck and let us know what you find
· Registered
Also check the wires between the points and coil, coil to switch, switch, switch to battery. Intermittant problems are a biatch to track down. When it's doing it (no spark), try hotwiring the coil and see if you get spark, That eliminates half your circuit right there.
Points and a condensor are about as simple a system as there is. A few jumper wires and that's about all you need to diagnose it. I used to use 6 cylinder Chevy parts. Every auto parts store carries them.
· Registered
Discussion Starter · #6 ·
Thank you very much for the feedback. I will be trying all of the suggestions received so far. I am new to this classic Harley deal. The parts I bought came from the dealer. Honestly, I am a little skeptical (is the little emblem worth the cost?) as far as the parts HAVING to read HD on them. Like I said, I am new to this. ANy GOOOD parts sources receommendations appreciated.
I do not even know where the circuit breaker would be. The voltage regulator (the original) is not hooked-up to anything. It appears to be there just for looks?
I still need to purchase a manual. HOWEVER, as you can imagine, the bike is not all stock, so I am not too sure how much help the manual will be.
Thanks again.
