Hi all and thanks for taking the time to read this,
I have just done a frame off on a 1986 FXR. It is completed now starts great, runs great, looks great!!! But it is not charging. I had the battery load tested, 495CCA 12.5volts, good battery. I checked the stator for continuity, and shorts, tested good. Ah Ha I say replaced the regulator. Being a newbie to this alternator stuff I bought the correct regulator for my 1986 trouble is someone had upgraded to a 38amp charging system. Since there is no return on electrical I decided to go ahead and match the Stator to my new regulator. Still not charging. I checked the grounds, all tight, I stabbed the hot wire coming out of the regulator and checked for voltage there still no charge. The instalation instructions on the regulator said to run it to the AUX terminal on the main circuit breaker(that terminal supplies the switch). The original wiring had it wired to the Bat terminal. I don't get the difference, there is continuity thru the breaker. I pulled the primary apart again to look at the rotor. It looks intact. Tomorrow I'll reassemble and swap that wire over to the other side of the main breaker I sure dont see what that'll change. Any suggestions? Am I overlooking something? Please educamate me.
