When changing to 3.37 gears do you need to get a new primary chain? I know that on chain drive bikes, when changing a final drive sprocket, it is recommended to get a new chain, does the same hold true for primary chains and sprockets? If not, why?
Average Dude
If your chain is good, then it will fit. With the gear change, tou will be adding a tooth on one gear, removing one from the other. Therefore the length of the chain is not changed.
YB
