1 - 2 of 2 Posts
Craptacular
Currently running the S/E 255 cams in my 07 103" FLHTC and SERT. Have read that a different cam may help reduce heat and pinging. Would the map from the disk for my build work as a starting point for a different cam? Are there timing changes that would need to be made? I do not have access to a decent tuner in this area so have to work on my own maps.
Any recommendations on new cam?
Marc
The biggest change will come in the VE tables.....your new cam will be flowing more air and more that likely it will breath better in a different area of the map. once you get the fuel correct again then you can play with the timing to burn that fuel but again this all needs to be done on a dyno so you can see subtle changes in the direction your wanting to go.
1 - 2 of 2 Posts
