Doing What I Can
Hello DJR,
I need a PC V map for a 2001 Road King with the following modifications: 95" with SE flat-top pistons, heads ported by Big Boyz, Andrews 26n cams, M&M fuel injection, SE air cleaner, stock pipes with V&H 3" mufflers. Thanks, DGC
Sorry for the delayed response, attached is a map that you can try with your current setup. It may not be the best as head porting can have a huge affect on the amount of air flow to the engine. You also have the option of having a custom map made at one of our power commander tuning centers.
Hello DJR. When prompted to reset learned fuel trims after running auto tune should I? I am using the target tune option with wideband 02 sensors.2016FLHTCU with cobra power port pipes and thunder header mufflers, fuel moto pro billet air cleaner.
Sorry for the delayed response, but Yes it is always a good idea to reset fuel trims whenever you change anything that will affect the amount of fuel the engine getting.
