WTF?
My '16 Road Glide Ultra had the water pump and thermostat changed in August 2018. Again this year in August 2019 I had the thermostat replaced after a coolant leak was discovered on a ride. I've had the bike back a week and I got the dreaded engine check and temp lights. I had rode about 45 minutes and stopped for about 15 minutes. Got back on the bike and the lights came on after less than 5 minutes. I shut the bike off for a few minutes. Started it up again, the lights remained on. After about 5 minutes the lights went out. The fans were never on.
Any ideas why the lights would come on then turn off? I'm at wits end with this bike.
You will need to scan the ECM. It will probably steer you in the right direction. Using a scanner I would check how hot the ECM thinks the engine is.
