I have a 93 FXRS-Conv, the plastic ell outlet cracked. Why did HD even use plastic? Oh well. I am installing a pingel, the aftermarkets did not have a 22mm adapter. The pingel mounted fine in the bung hole, problem is the gas line. The pingel outlet (forward ) is about 1 and 1/2" shorter than the OEM or said another way 1 1/2" closer to the tank. The fuel line goes through a hole in the VOES bracket and there is not enough room, because of the bracket size, to bend the fuel line up to the outlet of the pengel. Only choice I see is to remove the tank and reroute the fuel line over the bracket, but not excited about that choice. Any suggestions, experiences are appreciated.
