I am trying to get the seat off an 05 heritage. I bought it used, and it does not have the seat strap.
I removed the thumb screw from rear fender. no problem it came loose.
Then I removed the two thumb screws on each side of heritage seat. The screws are backed out, but the seat is not loose. Why did the driver seat not come loose, and the rear seat did?
You may have to pull on the sides of the seat to loosen them from where the thumb screws hold it on. The sides will kind of pop off then you can lift the seat off.
There is a 'tang' under the nose of the seat that goes trhouh a loop on the frame. You have to pull back on the seat to get it loose. Sometimes you have to pull back and up on the rear to get it clear.
