Tony Kebhart
MM EFI
Stock ECM
V&H Longshots
Arlen Ness big sucker
Just added andrews TW26A cams.
I have done a search and havent really found anything. anyone out there running this config?
Also...should I do the Stage 1 Flash at this point?
Need A Map
I also need a map for my build
2001 Magnetti Marreli FLHTCI
95 inch
Screamin Eagle Flattops
Scottsman Heads
Andrews 37 G Cams
Throttle body ported out with 42 MM butterflies
50 PSI fuel regulator
Power Commander III USB
95 inch
Scottsman Heads
Andrews 37 G Cams
What pipes do you have? That's very close to my build. I have propipe. If you have the same pipe or similar 2into1 let me know and I'll see if I can get a copy of my map from the tuner and forward it to you to use til you can get to a dyno...
