About 5 or 6 months ago, I asked the board about bigger valves and head work to improve flow in my heads. I was to do the work myself.
http://www.v-twinforum.com/forums/showthread.php?t=58017&highlight=Flong
Since then, I've bought 3 sets of take off Twin Cam heads off eBay and a diy style flow bench:
http://www.diyporting.com/flowbench.html
I already have hand tools to r/r valves and guides and have since bought porting tools, mainly from Mondello, Goodson and AV&V.
Its been an interesting compulsion and I now have a head I'd like some comment on. First, I've just purchased a 98 inch Revolution cylinder kit and Andrews 37G cams from HDWrench so that is the set up I'm looking at. My bike is a '05 Softail Nighttrain with RB Racing Black Hole pipes (1.75 inch diameter pipes, bung for O2 sensor) SE aircleaner and stock EFI with a Techno Research brand of SERT.
My first set of heads ('04 take offs) have become my "mules" mainly because I botched the job - the cost of experience I guess. These were to have 1.9 inch intake valves and stock exhaust valves. My current set that I listed below are '05 take offs.
HD 2005 heads, ported and flowed,
stock '05 valves and valve guides,
stock intake manifold port diameter.
5 cc of material removed from intake port.
about 1 cc from exhaust port.
no porting to the valve guides bosses or the roof.
standard factory 3 angle seat.
The short radius was not lowered - still measures the same distance from the head gasket surface as when I started.
I haven't even blasted the "paint" off the combustion chamber or exhaust port but I did clean up the valves and valve seats of carbon.
Flowed at 28" SCFM with clay radius on intake and no radius on exhaust.
Lift - Stk Int - Stk Exhaust - Prtd Int - %- Prtd Exht -%
.100 - - 80 -- 26 -- 80 -- 0 -- 28 -- 7
.200 --133 -- 86 -- 135 -- 1 -- 91 -- 6
.300 -- 185 -- 120 -- 189 -- 2 -- 130 -- 8
.350 --201 -- 132 -- 206 -- 3 -- 145 -- 10
.400 --207 -- 139 -- 214 -- 3 -- 152 -- 9
.450 -- 205 -- 143 -- 219 -- 7 -- 155 -- 8
.500 -- 203 -- 146 -- 224 -- 10 -- 157 -- 8
.550 -- 203 -- 146 -- 224 -- 10 -- 159 -- 9
.600 -- 205 -- 147 -- 223 -- 9 -- 160 -- 9
What I did in the intake port was widen the floor - made it look more like the letter "D". Removed the aluminum from the valve seat underhang and slightly round the bowel, especially on the sides of the port. Then, and what made the most difference (by about 20 SCFM increase) was reradius the short side radius from the valve seat back to the apex of the short side.
The exhaust port was opened slightly on the short side radius at the exhaust gasket surface but not greater than a 1.5 inch diameter I drew on the exhaust gasket seating surface. Slightly egg shaped. Then I took off some metal to shape the short side apex more like a "D" and lowered the floor from the apex of the short radius to the outlet.
My questions are:
How am I doing? I can't find any listed porting numbers or % increase for commercially available ported '05 heads with stock valves , especially on '05 heads with their smaller intake valve.
Is this a significant increase in flow and is it helpful for my 98" Andrews 3G build?
How much gain is there from radiusing the valve guide bosses and/or changing to more streamlined valve guides? Different valves? Raising the roof?
Different valve seat radius will take an expensive tool (A hand driven Serdi with holding fixture is $3500.00). The only available cutter I know of for this tool and HD heads is made by Mondello and available from Goodson. What kind of gains am I leaving behind using the stock valve seat radius'?
Opinions welcomed.
Thanks.
Frank
http://mondello.com/
http://www.av-v.com/Introduction.htm
http://www.goodson.com/
My questions are:
Opinions welcomed.
Thanks.
Frank
