Screamin' Eagle
After quite a bit of feedback from the forums and working with the hot-rodders at St. Paul Harley, I completed my 95" build on my 2004 FXDI. My goals were to do a Screamin' Eagle build, get plenty of power for 2-up riding with the wife and have a bike that was as "snappy" as my hot-rodded '89 Sportster that I ran 15+ years ago when I was in the Army. Well, I am done with my engine breaking (first stage) and am very pleased with the results.
The build:
95" jugs
SE Perf (MCR) Heads
SE Flat Top Pistons (10:1 compression) w/ compression releases
SE-251 Cam (.579 lift and shorter overlap)
SE Tappets, Perfect Fit Push Rods, Roller Rockers & Cylinder Studs
S&S Crank Case Breather
SE Perf Clutch Kit
SE Race Tuner
V&H ProPipes
- I also went all braided on my cables while the tank was off.
The low end torque is just what I had hoped for and once I get past the 3500 RPM (for the first time yesterday) the engine only gets better.
I did a 50 mile putt, changed the oil (using conventional oil), and then did another (cold) 450 miles keeping under 3500 RPM, and changed the oil again. I will be running conventional for another 500+ miles and then switch to AMSOil.
I tremendously appreciate all of the feedback, guidance, and help from forum members. This build has turned out far better than it would have without your help.
I will get some pics posted on Tuesday as the wether will be back in the 60s and the wife is begging for, maybe our last, river ride.
Cheers!
Thread Ender
What are you using for fuel management?
Screamin' Eagle
I am using the Screamin' Eagle Race Tuner. I forgot to put that in the build as I has previously purchased this to have my bike tuned when I bought it earlier this summer. I am currently running on a "break-in tune" and will have it dynoed and re-tuned once it warms up again in the spring.
