I have 10,000 miles on the deuce, 1550 big bore. I am going to mobil 1 v-twin oil. One question, what are you using in the trans, and primary? Thanks
Renegade
Redline MTL in the primary, Redline Heavy Shockproof Gear Oil in the tranny. Much quieter and smoother shifts.
You need to check out Amsoil, an get away from the Dino oil. they make everything you need . motor oil 20-50 V-tiwn. 10-40 for the pri., 75-90 for the trans, also have filters. smoother running and shifthing. www.amsoil.com #537787
zzloc KEEP THE RUBBER SIDE DOWN:D
