Does anyone use (and recommend) this oil filter? Better yet, does it fit properly? According to the oil filter cross reference charts I've seen, the answer is yes. But charts and experiences aren't the same.
This is your filter info it may help.
Amsoil
1450 FXST Softail Standard 2000-05 SMF134 Black
1450 FXST Softail Standard 2000-05 SMF134C Chrome
1450 FXSTI Softail Standard F/I 2003-05 SMF134 Black
1450 FXSTI Softail Standard F/I 2003-05 SMF134C Chrome
Filter Diameter 3”
Filter Length 3.56”
Filter Thread 3/4-16
Filter O.D. / Gasket I.D. 2.81 / 2.48
Wix Part Number: 51348
All Applications
Style: Spin-On Lube Filter
Service: Lube
Type: Full Flow
Media: Paper
Height: 3.404
Outer Diameter Top: 2.921
Outer Diameter Bottom: Closed
Thread Size: 3/4-16
By-Pass Valve Setting-PSI: 8-11
Anti-Drain Back Valve: Yes
Beta Ratio: 2/20=21/37
Burst Pressure-PSI: 275
Max Flow Rate: 7-9 GPM
Nominal Micro Rating: 19
Gasket Diameters
Number | O.D...| I.D.....| Thk.
Attach. | 2.734 | 2.430 | 0.226
