Obviously this approach will only work on FLH/FLT bikes with air in front forks. HD service manual lists 2 ways to refill forks, 1 way being thru the drain hole. Does take 2 people though. I get my wife to help me if I'm at home. You just have to let all air out of forks, remove the inside from the front air valve, drain both forks, put drain plug back in one side, insert a piece of battery vent tube into the other drain plug hole. Put recommended amount of fork fluid in some type of container, put other end of battery vent tube in the container. Setup the MityVac to suck rather than pump, use one of the MityVac tapered attachments into the front air valve, slowly start pumping. The fork oil will be drawn up into the fork. Once all the fork fluid has been drawn in, keep pumping while other person pulls the battery vent tube and inserts the drain plug screw(quickly). Repeat for other side.
