sounds like its time for some trans work could be anything from maindrive gear ,shift fork, shifter drum ,set up to slider gear,door bearings, and it is 22 years old time for a look see
Ok, this has a rear chain drive, is it enclosed in an oil bath or is it exposed? Why do you think it has a shovel bottom end and a EVO top end? The 84 FXRS was the first year EVO motor.shvlution said::duh?: Now theres some information i can use...
I was hoping that maybe someone has experienced this type of a problem before and might shed some light as to Isolate the problem. The obvious not included. ~Thanks
FAQ's said:2. Flaming of other members will not be tolerated. You cannot verbally attack another member just because you do not agree with his or her post. Everybody is entitled to voice their opinion via this forum.
In order to exercise that right, your posts must be done so in a respectful, tasteful manner.
Well, if you're sure, I guess you gotta get in there.shvlution said:It is definately in the transmission.
~shvlution
