1 - 2 of 2 Posts
Hi, I just ordered Wild1 mini apes 8.5 for my Fatboy. They tell me I can use my stock cables,,,etc....Am I missing something, or if I want to just change out bars,,,,can I just slip off grips, etc...remove stock bars,,,and replace with the Wild1's? Is there anything I am missing....thank you for the help.
fair to partly cloudy
yeah it could be just that easy unless you want to run the wires internal
which isn't really that hard...the connectors easily come apart to remove the wires (make a map of the colors to the pin #s)
everything reached on mine except the wires to the handlebar mounted turn signals so I relocated those under the passing lamps
you might have to reshape the brake line a little but it will work
1 - 2 of 2 Posts
