Metzeler shows 3 options on their website when I pull up tire sizes for an 05 Road Glide....two sizes with asterisks and one without...but I can't find what the * are for. Probably a DA question but could someone tell me? Does anybody have a 130 tire on the front and can I do that without any mods? Thanks
2005 Road King Classic
A 130 (72H load) will work on the front and a 140 (77H load) will work on the back. A 150 will fit on the back with some work to the belt drive guard but the Metzeler 150 does not have a high enough load rating for any of the touring bikes. Avon has a 150 with a high enough load rating just in case you were thinking about going with a larger tire on the back.
If the load rating is not the same or greater on the tires it will reduce your load carrying abilities.
Thanks wkohn. I'm wanting to go with Metzelers so I think I'll try a 130 on the front and put the 140 behind.
Make sure you check out the load rating on them. From what I read they have a lower rating than the Dunlops. Avons might be a better choice because of them having the higher load rating like the Dunlops.
Will do. 'preciate the info.
