Is there a generally accepted set-up for measuring a cylinder heads flow rate? Manifold on or off? Header pipe on or off? Flow at 28 or 10 inches of water?… Etcetera.
Thats just part of the problem. Now throw into the mix air temp, humidity, barametric pressure and you have the reason head flow numbers are completely subjective.
