1 - 20 of 132 Posts
Please only Post Maps, their description, the parts used with them (including model numbers) and dyno run if available in this thread.
Road Captain
This thread is for posting MAPS only! All comments (other than the person posting the MAP) will be removed............
If you have questions, make a note of the poster's name and ask the question in a new thread or the one already open for discussion.
LAST WARNING
2005 FXDX
Stage I (AC and ECM flash)
HD slash cut slip ons
SE-203 cams
PC III USB
Before
HP 69 Torque 82.6
After
HP 75.5 Torque 85
MAP for '06 Tourer with Stage-1 & V&H exhaust
I had my '06 Street Glide Dyno-tuned and had a custom map made. The dyno-tune was done at a Dynojet Approved tuning Center. My bike is running great now. I thought I would share the map with anyone who may have my set-up.
My bike's particulars
2006 HD Touring Model
Vance & Hines True Dual headers
Vance & Hines Oval slip-ons
Screamin' Eagle air filter
Stage 1 ECM
25º injectors
(the reason I mentioned the injectors is because I originally had the 8º injectors but it probably doesn't matter)
**use at your own risk**
http://home.comcast.net/~ehicks/06_Tourer_V&H.zip
~eddie
Road Captain
07 TC 96 Screaming Eagle and K&N Filter for touring models
This map is an advanced map, where each cylinder is tuned separately.
2007 Twin Cam 96 on a Road Glide, but all touring should be the same.
Screaming Eagle Exhaust
K&N Filter
I started off with a Fuel Moto map, which gave me 69 HP and 84 Torque.
I ended up with 76 HP and 90 Lbs/Ft of Torque with this map.
Map
K&N Filter
Yup that's where I'm at, 69 and 83 with fuelmoto map on 07 RK Custom with stage 1 filter and Sampson Silverbullets. Where did you get your advanced map?
Red Rider @ 43rd & 7th
Power Commander map
Use at your own risk. I developed this map for my 2006 FLSTNI 88in. with Hooker Header Rebel Drag pipes and a screamin Eagle AC. No other engine mods.
Dyno Results
'05 FLHRCI
Stock 88
Stage 1 ECM
SEAC
V&H True Duals
V&H Ovals
PCIII USB
Max HP = 65.31
Max Torq = 69.58
Max HP = 70.71
Max Torq = 72.58
06 Softail Stock ECM
Attached is a custom map I just had done.
Build:
2006 Softail
95 SE 10:25.1 cast pistons
TW44 Cam
.040 Cometic
SE Air Cleaner
V&H Big Radius
Stock ECM
Bike runs good now. Made 83HP, 93TQ
2007 Map
2007 Heritage Softail: Factory stock pipes, PCIII-USB, K&N air filter. Setup & tuned on Dynojet, O2 sensor eliminators installed, Rev Xtend enabled. Went from 56HP to 70hp & 76 lb Torque. High heat, surging and pinging now gone.
1 - 20 of 132 Posts
