Map Request: 2010 Iron 883 - PCV + Autotune. Pls
Hi,
I installed my PCV and Autotune to my 2010 Harley Davidson Iron 883. I have the Vance and Hines Staggered Short Shots and Screamin Eagle Heavy Breather on the bike so I chose map (15-009-006) from the Power Commander site as this best describes what I have installed on the bike.
I rode the bike for an hour and found a couple of issues.
The bike had several flat spots when accelerating as if the bike was hesitating when the throttle was engaged.
If I try to ride at a constant speed (20-30kms/hr) the bike is very rough and almost feel I need to accelerate so to smooth it out.
On deceleration the exhaust constantly pops. I understand some popping is unavoidable but this is actually quite bad.
Note: The bike idles fine at standstill and does not switch off.
I previously had the Scremin Eagle slip on mufflers with the stock air cleaner and stock ECU and had no issues.
I live in Australia so should I be using a different map than those on the CD/PC site or Is there a better map that would be suited for my bike?
Also I was under the impression the Autotune would adapt to the requirements of the bike and make any changes necessary.
Hope you could help.
Hi,
