1 - 8 of 8 Posts
· Registered
Hello
Bike is a 2006 ultra classic with the harley 103 build including 253 cams, K&N and slipon mufflers taking it to 1690cc. Bike has had proper HD download for this build. Ive had difficulty finding something, assistance is MUCH appreciated!
· Registered
Discussion Starter · #2 · (Edited)
Gee....mine is a pretty common setup from HD........I would have figured that the was multiple maps for the power commander on this as long as it has been around....:huh:
· Premium Member
Sorry for the delayed response. In regards to the download from Harley, do you know if it was just one of there stage downloads, or was it a down load using the Race tuner or Super tuner, as this will make a huge difference in our ability to help you with a map. For a faster response you can contact us at, [email protected]
· Registered
Thanks for the reply. The download was the "canned map" from Harley. Also as a side note, the bike has 25 degree injectors. Thanks again!
· Registered
Discussion Starter · #7 ·
Sir
Thanks again for the map. It ran fat in my bike, idle just would finally quit. I received a call from your tech line and they suggested a map from your site which I made some modifications to, both fuel and timing. Runs great and smooth, going to check again tomorrow but Im also getting 43mpg with it. I may have to drop the timing a degree or so in some areas as I "think" I may hear pinging.....but it also sounds like the injectors, so I guess I will continue testing.
Im posting so other may see it as well, but as with all things, use at your own risk.
Mr. Dynojet, take a look and see what your thoughts are.
Regards!
1 - 8 of 8 Posts
