1 - 9 of 9 Posts
Hello, i,m, new on this forum, i,m from spain and i have some ask for all people who want help to me.
I have a FLHRCI 2002, and i put a new scream eagle on my bike, but i don,t like the sound of it, my question is :
can i make holes on it? have any problem for my Twin Cam machine or efi system?
Thanks in advance and sorry, sorry for my bad english....
P.D. : congratulations for the forum.
Once you put the Screamin Eagles on the bike you should also have the fuel injection reset... Running a wide open exhaust without any back pressure could effect the fuel mixture and cause some plug fowling... Your english is pretty good... I understood everything you wrote..
Never heard of putting extra holes in Screamin Eagles... Seems like such a waste to do that.... I would punch out the restrictor disk on the "stock" mufflers before messing up the Screamin Eagle Mufflers..
Merry Christmas and welcome to out little forum...
Doug
Your not going to get much better sound from the S/E pipes. As long as you do not add a S/E air cleaner the stock EFI is fine. The bike would run better with a EFI reflash but the factory setting will handle new S/E pipes. Better pipes that flow more would need a EFI reflash.
I have heard of people drilling the S/E baffles holes bigger, this will make the pipes louder and flow more then needing a reflash if none was ever done.
Thanks very much to all , i make the holes and tell you what happen...
Thanks again and merry Christmas too.
Hello to all again, i,m talk with my mechanical and say to me is no good make holes to my Road King Classic, because the exhaust have a sond lambda ,and with this holes the ignition can make it crazy.
I don,t make it and go with the same sound :-(
Best regards
Tome su tiempo, espera hasta que usted puede comprar silenciadores
nuevos y después cambiarlos.
Jimmy, your such a show off.:D J.T.
Sein müssen ein haltbarer Job aber jemand es tun. LOL
Uh....alles klar. J.T.
1 - 9 of 9 Posts
