I just finished most of the 20,000 mi maintenance, and I have a couple of questions fro the Service Manual:
1. Can the rear belt deflection be adjusted by just 1 person?
2. There is no guidance for suspension adjustments. Is there any elsewhere?
3. The throttle and idle cables got in the way of/impeded the fall away test. Is there a preferred way to preclude this?
4. Where are the fork stem bracket pinch bolts?
5. What size are the fork tube caps?
6. In trying to adjust the idle cable, I could not determine whether the cable housing ever touched the spring in the cable support sleeve. I only saw the idle cable take up slack around the throttle cam. I just adjusted the idle cable adjuster until there was little play in the throttle grip at the 0% throttle position.
7. My rear fork pivot nut is covered by my Kuryakyn Adjustible Passenger Pegs. SHould I remove the peg to get to the nut?
8. I could really only get to 1 of the enging mounting nuts (I also need a bigger torque wrench). Are there any tips to getting to the lower nut?
9. What king of socket should be used on the brake banjo bolts (and other similar brake bolts)?
10. WHere are the pinch bolts for the front fork?
Whew.
Thanks all,
Whew.
Thanks all,
