Does anyone know of a Mass Air Flow Fuel Injection System for H-D's?
Administrator
From what I understand a Mass Air Flow sensor needs a more consistent flow of air than a 2 cylinder Harley engine will draw. This makes it impractical for use on a Harley, not to mention the large ugly sensor that would be required.
Thats right, with 4 cylinders and less the intake air flow is bidirectional and the pulses are additive, therefore the wrong flow data because the sensor does not detect direction, just flow, whether it's in or out. If they could blank out the wrong direction flow and smooth the pulses through signal processing, it is possible to do but the volume of production for efi Harleys is too low to justify the R&D expense to make it reality. Therefore we get speed density which requires a recal anytime we make a change to the "system".
Just pidlin'
Reed valve
I understand what you all are saying, I wonder if anyone has tried a reed valve on a Harley, That would stop the pulses.
I have to ask 'Why?' As the the previous posters have said, MAF sensors need a constant air flow to be effective/accurate. A reed valve would stop the 'back' flow, but you would still have pulsed air flow through the sensor.
killer sperm
Even the pulses from the cooling fan on your favorite V-8 can confuse the MAF if the air intake is moved too close.
Discussion Starter #7
Thanks. These have been enlightening answers.
